G/MAN NEED OPINION ON A G BUILD-UP
B Barenie
01-25-2006 05:44:27
Have an tractor puller buddy who has a 9.5" g stroker crank, with a power block !
This individual wants to run 6.5" x 9.5" .
Who would you recommend for custom pistons, and billet rods ?
Do you have an opinion of how long a rod to run, and where to set wrist-pin height ?
With the rite head work, does 130hp sound reasonable.
Also would you advance cam timing, said person has a cam ground to a specific spec. , don't no if that is correct !
Just looking for an opinion on a good stout build-up.
Any help would be greately appreaciated !
jd b puller
01-26-2006 19:09:46
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to B Barenie, 01-25-2006 05:44:27
Bud, 180HP isn't unreasonable. After all you didn't tell us what you wanted to run for RPM... Crank her up to 3000 RPM's and stay back 500 feet. you should be fine.
B BARENIE
01-26-2006 05:39:45
THANKS FOR ALL RELY'S PERTAINING TO THE ENGINE BUILD-UP !
BUD BARENIE
skip 33652
01-25-2006 16:46:21
130 horse wont happen 100 maybe.the bigger G's are 7.5" by 9 3/4" plus very few make 125 horse. rods can be welded heinrichs or schooler should be able to help with pistons. as far as rod length as long as is possible is best.Paul
Drew
01-25-2006 10:24:52
Murphy's Motor Service can make billet pistons and billet rods www.murphysmotorservice.com
Unless you get in a space crunch, I would put the wrist pin as high up in the piston as I could get it w/o getting into the oil ring.
I agree with G/MAN, 120hp sounds a lot more realistic than 130.
You say you have a reground cam, do you have the cam card that should have come with the camshaft? If so, it should tell where the intake centerline should be when it is degreed in. If you dont have the cam card, its kind of a guess as to where to put it. Most of my "A" cams are to be set up with the intake centerline 104-106/107 degrees ATDC. Depending on what exactly you have, this may be a good place to start. Degreeing in your camshaft IS important. If you just put the camshaft in and dont degree it in, it may be close, or it may be somewhere off in never-never land. EVERY cam is a little different.
toot
01-25-2006 09:43:09
I don't know if had any cam modifications, but I will share a short story: I had a friend with a 6.5 X 9 model G with a cam ground by lunati. Had no torque at all. He put the F900R G/70 cam back in and it came to life. I not saying cam modifications are a bad thing, but the grinder needs to know a lot of variables before the work is done. Your dealing with a low rpm engine, etc. not a hot rod.
G/MAN
01-25-2006 07:36:49
I'm not the "Gman" you want. Get with JDGnut, Gman, Earl S. or one of the other guys on here that knows way more about building "G"s than I do. I would say that billet rods probably aren't going to be necessary, and are going to add a considerable chunk to the bill. A good friend of mine has a "G" in the 700+ cube range, and he's used welded rods for years and years with no problems. He's running a Power-Block sleeved to 7 inches, Jahns pistons, Jerry's head and manifold, etc. I think the stroke is 9 3/8" or so, but I'm not exactly sure. It's a pretty stout tractor, and we figure it to make 100 horsepower pretty easily. Maybe up in the 120 range. I'd say getting 130 horses from 630 cubes is going to be a big stretch.
ChadS
01-25-2006 06:21:56
Bud, that G would be a good one, If its the one Im thinkin,, Gman, he keeps breaking cranks in it, he really dont work the engine that hard, it just seems to have no torque on the low end. just falls on its face. Im not knocking that G one bit now,, but he does need some help with it! To me, it sounds like the cam is not right for it, it just wont lug out. he really dont abuse it,, it just seems like when it does get to running good, it breaks, For what he has done to it, it should run lik a scalded dog! It just,, dont sound right... The deep resonating 2 lunger pop aint there. it sounds kinda lazy. hope this would hep a little more with some info on it,, Chad
AC
01-25-2006 17:21:36
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to ChadS, 01-25-2006 06:21:56
Speaking of G's, what ever happened to "4th gear Darrel" ? Loudest G I ever heard...AC
ChadS
01-25-2006 18:34:31
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to AC, 01-25-2006 17:21:36
I seen Darrel at goshen, but he left the big G at home. he is driving truck, and gosh knows what,,, he is still around, and still has the G. He needs to come out and play. that G, I never seen break, only a tranny gear one night at Argos. Super Strong G, and in my opinion, done right. Now if you ever seen Mike Thompson's 37 A, that was a stout SOB!!! That was before your time in NCIATPA,, but an honorable mention. Chad
AC
01-25-2006 19:01:44
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to ChadS, 01-25-2006 18:34:31
What will be the hot tractors this year in NCIATPA?
ChadS
01-26-2006 05:34:58
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to AC, 01-25-2006 19:01:44
The ones that dropped out of the modified division, and into the farm stock division. AND, the tractors that have to be altered to keep up. LMAO! ChadS
AC
01-26-2006 15:46:20
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to ChadS, 01-26-2006 05:34:58
That leaves who? You, me, Terry, Joey, and thats about it, isn't it in the 0 to 4000 class? Oh yeah...beware of the ZB..its out there... ;) later...AC
ChadS
01-26-2006 17:30:31
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to AC, 01-26-2006 15:46:20
Yeah, that about sums it up. I just picked up a 50 M today. I had to tarp it while bringing it home though,,,, the darn thing is painted John Deere green and yellow! LMAO! Its getting stripped out, stroked and bored. Just picked up the block Im building for it, Im working on getting down to under 4000. I seen a photo of that ZB,,, that should be a nice little puller! I just finished dropping in a new engine in a NCIATPA competitiors tractor,, Gonna hear it run tommorrow,,, Chad
B BARENIE
01-27-2006 04:01:57
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to ChadS, 01-26-2006 17:30:31
A YELLOW AND GREEN FARMALL !
DUE TO THE COLOR MODIFICATINS THAT TRACTOR WILL NOT BE ABLE TO PULL IN YOUR CLUB !
BETTER READ THE NEW RULES !
SECTION (3) UNDER FARM STOCK RULE NUMBER (6)
ChadS
01-27-2006 04:10:24
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to B BARENIE, 01-27-2006 04:01:57
yep, yeller n green. Bought it from Hopper. Good ol tractor still, cant wait till it warms up to throw some red paint back on it. Dad said, he wants to pull it like that,, I said, aint no way that thing is leavin the farm like that. Chad
SM-53
01-27-2006 04:33:21
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to ChadS, 01-27-2006 04:10:24
ITS 7:00 AM MY TIME
I DIDN'T THINK YOU WERE UP TILL AROUND 10.30
HAAAAA A LOLLAL
ChadS
01-27-2006 04:42:34
 Re: G/MAN NEED OPINION ON A G BUILD-UP in reply to SM-53, 01-27-2006 04:33:21
LMAO. So much to do, I cant afford to sleep In!! Shouldnt you be on the road by now? sell them nutz n bolts! Did you find a rod yet? Chad
