10A4210 heads on U MM
Joel
03-18-2002 19:18:00
I am replacing the GE-30E heads on my U MM with 10A4210 heads. Will I be able to run regular gas? Will these heads work alright when using the tractor for field work? These heads are about 1/2" shorter than the original. Will I need to use shorter push rods? Thanks
Andy
03-19-2002 09:38:19
 Re: 10A4210 heads on U MM in reply to Joel, 03-18-2002 19:18:00
This is a good all all around head for a U. You will pick up a few hp over the 30 E's , (same as 4209). The UB's used 4210 heads as a gasolene head.
Dave N
03-19-2002 05:08:13
You should have about 7 to 1 comp. need shorter pushrods. also you may have to use spacers under the head bolts.
