H gearing
CLIFF S
01-27-2006 18:35:10
I have 2 Farmall H rears, A 1945 with a strait cut ring and pinion and a 1947 with a curved cut on the ring and pinion, Becouse the 47 is still together i can only count the teeth on the pinion and there the same count as the 45, My question is are they the geared the same? And What do you use to get the nut off that drives the pump and is it left or right hand thread?,I need to replace the seal.
