Governor
Needim Helpim
03-19-2002 06:44:41
Can I get 2500 RPMs out of my 4 cyl. tractor without messing with the governor. What can I do to the weights to help me in a 2500 rpm class. Will it help to lighten them up?
tim
03-19-2002 10:54:34
 Re: governor in reply to Needim Helpim, 03-19-2002 06:44:41
Use a stronger spring so you can work against the govenor a little more or if you lighten the counter weights that will make it easier for the throttle spring to open up the butterfly. Do it by drilling. Then you can always add the weight back in if you want to or balance them better.
