Hey Barenie,, cams,,,
ChadS
02-01-2006 07:13:06
M cam:
INTAKE: .423 lift
duration 257.60
lobe sep angle, 109.87
EXHAUST: .415
duration: 277.22
Lobe sep angle: 109.87
SM-450 cam:
INTAKE: .434
duration: 265.81
lobe sep angle: 109.64
Exhaust: .415
duration: 271.07
ChadS
LW
02-01-2006 19:19:07
 Re: Hey Barenie,, cams,,, in reply to ChadS, 02-01-2006 07:13:06
If you have a "stock" cam that you believe has little to no wear you should have it checked on a Cam Doctor that will give you the Durations @ .050 tappet lift as the stock cams were ground with much ramp to be long lasting, Total duration is a very skeptical number to deal with. You could have to lobes with the same seat duration that would be 20 deg. differance at .050 tappet lift....
Drew
02-01-2006 20:23:11
 Re: Hey Barenie,, cams,,, in reply to LW, 02-01-2006 19:19:07
You make a very good point that not that many people realize. You can have 5 different camshafts that all card the same, even have the same @.050" numbers, but all become very different at .100, .200 lifts etc. And when you throw rocker arm ratio and roller grinds in the picture everything changes again.
ChadS
02-02-2006 06:21:46
 Re: Hey Barenie,, cams,,, in reply to Drew, 02-01-2006 20:23:11
Its not as easy as it looks is it? Least when you buy a cam for a chevy or a ford, you may have an idea on whats going on,, You guys gave some good info! Any thing else that we need to know? This helps everybody! Chad
ChadS
02-01-2006 19:29:23
Your right. Maybe I should have copied the cam sheet out and posted,, LOL! so many darn numbers to look at, enough to make you go crosseyed. at .050,, they look like this,,,
M:I: 193.05
E: 208.79
450: I:194.52
E:207.86
CHad
B BARENIE
02-01-2006 19:57:10
 Re: chads---baker---lw in reply to ChadS, 02-01-2006 19:29:23
CHADS---BAKER----LW
JUST TO A READING OF A SM-450 EXHAUST LOBE.
DID IT FAST AN SLOPPY, GOT TO GO TO BED .
CAME UP WITH .263 , SO THE BAKE LIFT ON EXHAUST # LOOKS FINE TO ME
CAM DOCTOR ! aNOTHER AWESOME TOOL , NEVER HEARD OF IT !
ALL I CAN SAY IS IN THE LAST COUPLE OF MONTHS, BAKER AS EXPOSED ME TO TECHONOLOGY, THAT I COULD NOT REPEAT. CHADS----LW GIVE BAKER A CALL, HE COULD EMAIL YOU STUFF AND SHOW YOU PICTURES OF THINGS THAT MY MIND CAN BARELY COMPREHEND !
good night gentlemen !
LW
02-02-2006 20:05:29
 Re: chads---baker---lw in reply to B BARENIE, 02-01-2006 19:57:10
The first time I talked to Gary It was a short 2 hr conversation we both face a lot of the same issues and agree on a lot, He is sharp and is doing a ton of work to those red tractors, He probably puts more work into a carb then alot of guys would do on an entire engine, I would like to do cam for him and see If I could make him some improvements. It might not but I think outside the box.
Gary Baker
02-01-2006 15:41:53
Hey Chad, I measured the lift on a stock 'M' cam and cam up with totally different numbers than you have! Intake lift @ lifter is .270 & exhaust
was .265 Gary
ChadS
02-01-2006 18:47:28
 Re: Hey Barenie,, cams,,, in reply to Gary Baker, 02-01-2006 15:41:53
Whoops! read the sheet wrong. that was peak valve lift, , try this,,,
M: intakes, .266
exhaust:271
450: 272 intakes
exhaust: 271.
Sound better? Sorry bout that! Chad
B BARENIE
02-01-2006 07:35:34
i'LL REALLY STUDY THAT LATER, BUT IN FIRST GLANCE, NOT MUCH DIFFERENCE !!!!
ESPICIALLY LOBE SEPERATION !!!
LOOKS LIKE A FIELD ECONOMY CAM ! FUEL MILAGE !
DID YOU DREAM THOSE NUMBERS OR ARE THEY CORRECT !
ChadS
02-01-2006 09:45:21
 Re: Hey Barenie,, cams,,, in reply to B BARENIE, 02-01-2006 07:35:34
Straight off the cam reader! its the real deal. chad
