H or 350 governor
350 farmall guy
02-05-2006 05:31:49
Is there any difference between the H and 350 governor? I have a 350 without a governor but I have a H governor. If so what? What is the best to use on a 350?
Andrew Z
02-05-2006 09:27:52
 Re: H or 350 governor in reply to 350 farmall guy, 02-05-2006 05:31:49
I think there the same the only diffrence is the shaft that runs from the governor to the carb is shorter on the 350 due to the bigger carb. However I think intrenely there the same. The only diffrence that I can think of is that the H was rated at 1650 while the 350 was 1750. But I think that can be adjusted in the gov. (If that doesn"t work and your looking to pull you could always get a M&W gov. We got one in our Super H and what a diffence really snappy!!) Andrew
