B. Barenie
Chuck S.
02-12-2006 16:14:27
Budd I have gone thru my books and papers on subject 38 in rims on G MM. Most tire size changes for MM were handled at branch level, this usualy amounted to a credit to the invoice of the tractor. If you looked at a parts book for a G900 you will find only 15.5 and 16.9 X 38 rims . most were on 18.4 X34. It is very possible that a G MM could have 13 x 38 rims and tire,s. I have lost my G parts book. The cast center for a U is part #11B1372, 10A1372 should fit your hub. Also check your casting nos. The U used a double drop rim this should fit in place of a flat 34 in rim. Good Luck Chuck.
B Barenie
02-12-2006 18:02:52
 Re: B. Barenie in reply to Chuck S., 02-12-2006 16:14:27
Chuck:
I'm very much aware of the u ub retro fit, I know the castings will bolt rite to my existing pattern !
A g-moline would be fun to pull even on 15-5 or 14.9-38's Appreaciate your help !
I know they even retrofitted the g motor into u and ub's at the dealer level !
These old tractors need to pull, even in very much stock appearance , in the block !
When I was a kid I used to excavate with my dad with old td-9's, the one I drove never had a hood, just conduit from the radiator back to the instrument cluster-firewall !
Always enjoyed looking over the top of the valve cover !!
Thank you very much !
