Farmall H Compression
Farmall H Pulle
02-13-2006 14:16:47
How much Compression should a farmall h bored 3 5/8 and a ported 8043 head have?
Also should it spin out in 2 nd gear with 12 - 4 -38 on a loeser track in 4000 pound class?
Thanx Miles
ChadS
02-16-2006 08:36:32
 Re: Farmall H Compression in reply to Farmall H Puller, 02-13-2006 14:16:47
No, but it will work it pretty hard. A set up for a engine like that is a low gear heavy div 1 farm stock. Put that H up at 5000lbs, to start with, and load for bear. in the 3500, it may be good in second gear,, on looser tracks, but in low, you can play with some M's, if you weight it good. Chad
WILDMAN H
02-14-2006 03:52:49
IT WOULD ALSO DEPEND WHAT STROKE YOU HAVE . MINE HAS 265 PER CYLINDER.
wkpoor
02-13-2006 14:29:55
Are you asking for compression ratio or cranking compression?
Farmall h Puller
02-13-2006 14:35:56
 Re: Farmall H Compression in reply to wkpoor, 02-13-2006 14:29:55
Cranking compression please
