Combustion chamber on 350 LP head
42Farmall
02-14-2006 16:18:21
Does anyone know the height of the combustion chamber on a 350 LP head? Just the distance from the head surface to the highest point in the chamber. The 300 gas head I have is about .800" deep, I haven't measured the volume, and I was wondering how much difference there is betweeen them. Thanks to all.
42Farmall
02-17-2006 13:48:49
 Re: Combustion chamber on 350 LP head in reply to 42Farmall, 02-14-2006 16:18:21
Thanks, Chad Wonder how high it would raise my cranking pressure? It is now at 240.
ChadS
02-17-2006 07:31:56
Its alot less than .800! Probably a little over half that distance. The chamber is also wider, more bigger around than the traditional chambers. Stock pistons will work in most cases,, anything that is altered, better check for clearences. Chad
