Case cam grind.
fordson29
03-20-2002 18:56:57
I have always run fairly stock tractors and I hope someone that knows more about this can help me out. I am putting a VA series case together. I have a engine from a 400 I am putting the internal parts in the VA. I need to know how to figure the cam grind I need?? Should I just take it to the machine shop and trust that they know. I am planning to take it to Robert Sox in South Carolina. I also need to know what I have to do to fit these parts in. I was told a 148 from a 300 would bolt in, but the 148 from the 400 I would just have to change the parts with minor machineing. What minor machine work needs to be done?? Jonathan
buckmaster700
03-24-2002 05:46:26
 Re: Case cam grind. in reply to fordson29, 03-20-2002 18:56:57
good one old timer that method did work im my old garden tractor pullen days i hope he dont try it on his big tractor
buckmaster700
03-24-2002 05:46:01
Tim
03-21-2002 12:52:38
You have got to let the grinder know where you want the torque range to max out at. I.E. @2000
rpm.
You can call Lunati or someplace and see if they get all confused. They will also need to know the rocker arm ratio, maybe even the intake and carb size.
DCPuller
03-21-2002 06:49:33
I certainly Hope your not going to try and pull this tractor in the stock classes . If your building up a tractor like that then have the balls to run with the big boys . The stock class is for beginers and those with limited funds that want to have fun and its not fun when a cheater blows your doors off.
fordson29
03-21-2002 08:11:41
 Re: Re: Case cam grind. in reply to DCPuller, 03-21-2002 06:49:33
I am not going to pull stock. I have been hording parts to build this VAH high crop with a narrow front. I didn't get a front with the VAH. I am planning to pull up to 3500# Super and hoping to build a tractor that weighs about 2500#. No cheater here!!!!! Jonathan
geb
03-21-2002 06:37:49
Hello Johnathan,
Think twice before using Sox, there are several from this area that have some bad experiences with his work. I'm not tring to begrade him but I would be careful. J.T. and Buddy Richardson in Burlington are grinding cams now and I 've seen some of their work and it looks good. I not really promoting them but they do good work.
Gary (Goldsboro)
fordson29
03-21-2002 08:16:09
 Re: Re: Case cam grind. in reply to geb, 03-21-2002 06:37:49
Gary, If you have there # let me know. There is a Pull coming up in Four Oaks It is CATPA. Are you going. If so I will be there. Jonathan
geb
03-22-2002 08:22:55
 Re: Re: Re: Case cam grind. in reply to fordson29, 03-21-2002 08:16:09
Yea I will be in Four Oaks and also at White Oak this Sat and Sun (good show and pull) This is on Hwy 53 between Fayeteville and and Elizabethtown,
Richardson's number is 336-584-8254
oldtimer
03-21-2002 06:27:33
still goining to pull stock????Seriously ,check with some other pullers,some machine shops don't realy know how to grind a tractor cam they work with P/U's and autos that rev somewhat more than you plan on. Makes a lot of differance. I think a person could do better with a shop welder and a angle grinder than some I've seen preform.
