A good type of tire for pulling?
Allis Puller
03-20-2002 22:53:10
I pull an Allis "WD45" and I'm gonna put some new skins on it. Firestone are the cheapest and most available but will they be my while. My old set were Armstrong but they tell me that Titan only makes long bar short bar. Any input would be helpful.
Allis puller
03-21-2002 22:54:51
 Re: A good type of tire for pulling? in reply to Allis Puller, 03-20-2002 22:53:10
Thanks for everybodys opinion, but I've been lookin for quite some time for a good used set of 14.9's but they're hard to come in good shape. But I was planning on maybe spinning the new ones backwards on pavement or I was told running low air pressure down the road with weight on will help wear. What do you guys think?
oldtimer
03-21-2002 15:16:25
Firestone F/R Bought a wd allis 10yr ago,Had new Firestone F/R 14-9's on it pulling it stock.Kicked a lot of butt because of the tires. Still pulling it ,Had to get at the valves this winter,hope to kick more butt this year.
Shutt30
03-21-2002 08:28:42
If your going to pull don't buy new. They are much too soft and way too much lug. If you can, stick with the Armstrongs as they are larger for thier size. Goodluck
Greg H.
03-21-2002 10:13:40
 Re: Re: A good type of tire for pulling? in reply to Shutt30, 03-21-2002 08:28:42
Armstrongs might be larger with the smaller sizes, but on larger tires like 18.4x38's armsrtongs are slightly shorter. even though Firstone F/R's have a good inch in hight advantage, on 18.4 x38's the older Armstrongs have an extra bar per side to dig in, which makes a difference of nearly 1/2 inch less space, between each bar as you go around the tire. Sorry for the interuption, just thought I'd throw out some useless information. Later, Greg H.
Shutt30
03-21-2002 12:37:56
 Re: Re: Re: A good type of tire for pulling? in reply to Greg H., 03-21-2002 10:13:40
I have only used the 14.9-38's and smaller and I know that they are about a half size larger. Good to know about the larger ones though. Thanks
buckmaster700
03-21-2002 18:00:37
 Re: Re: Re: Re: A good type of tire for pulling? in reply to Shutt30, 03-21-2002 12:37:56
if you can get some old used wheather cracked firestones with about 5/8 inch of tread get them and kick some butt the older and harder the better
Shutt30
03-21-2002 18:34:37
 Re: Re: Re: Re: Re: A good type of tire for pulling? in reply to buckmaster700, 03-21-2002 18:00:37
My dad is using a old set of weathered wards riverside tires with about half tread. They are very,very hard. Now talk about taking power to turn!
