ChadS
02-25-2006 06:48:03
Re: Another Question in reply to Dave Slater, 02-24-2006 18:56:53
Is the main hood on the SMTA longer than the M? For weight loss, you mite be able to use the M front bolster, and pedistal, if the frame rail bolts are different, use the rails off an M. The steering hooked up basicly the same, and the power steering can still be used,, You would have to check to see if the steering gears are the same, or make one from a M. I was thinking the M-450 rail was the same length, just used different bolt patterns on the bolster, or maybe they are exact and interchange. But,,, power steering!! Gotta keep that. My H dont steer to well with 500+lbs of front weights sticking out there. Im thinking of how to put a 300 power steering on a H. 300 front engine cover, 300 live pump, and the 300 servo in the steering shaft, and hope, it fits under a H hood. And the live pump will be ok to run the power steering only. Too much pressure, or set it to match,, Can it be done? ChadS
