730 diesel pulling
4010 puller
02-27-2006 17:15:53
Hey guys:
I"ve done some previous tractor pulling but am completely new to this tractor, i just picked it up today. It"s a nice 730 diesel electric start with rollomatic front end and 16.9-38 loaded Firestones that are the 151"s (old field and road). I"d assume it weighs about 9000# now and plan to remove fluid from tires. How do you get more power out of a 2 cylinder diesel? How do you turn up fuel? It will be dead weight (tug) pulling.
Thanks!
ChadS
02-28-2006 07:28:19
 Re: 730 diesel pulling in reply to 4010 puller, 02-27-2006 17:15:53
We pull a 730 gas, and pull against a 730 diesil in deadweight pulls on asphalt. We have tried to get the best HP out of the 730 gas, but to find out, it was way too much power for what we was doing. So, we put it all back to stock,, plain jane 87 pump gas, and it pulled alot better. Now the 730 diesil had his pump turned up too, he had the same problem, he backed it down and just made it run good under power, and that tractor came to life on the asphalt. He was running 20.8X38 on 20 inch rims, in 2nd gear, we ran 2nd and third gear, with dualed up 15.5's. There was also a G that was hopped up too,,, we tuned it in back to stock, and that one does alot better too. Hope you see what Im saying,, its not really a big power style pulling, its all in the weight placement and the right power to the tires. JD 2 cyl's darn near dominate heavy deadweight pulls,, they are hard to beat. ChadS
