FARMALL H COMPRESSION
Farmall H Pulle
03-01-2006 13:11:07
I built a farmall H with 3 5/8 bore with slite dome, mild cam, and ported the head. It has about 4 hours on it now and im only getting 125 cranking psi. Should this be up in the 15 to 160. Is the engien not broke in good enough or do i have another problem? Is there enything else i can do to it to geta little more power? Does enyone have the steps to run an H on alky?
Thanx Miles
Farmall H Puller
03-03-2006 20:32:11
 Re: FARMALL H COMPRESSION in reply to Farmall H Puller, 03-01-2006 13:11:07
Hey W.B. have you ever dynoed that tractor of yours? If so how much did it have???
W.B
03-03-2006 12:04:49
I got one with 3 5/8 also. 350 head, cam and crank. Head shaved .080 When it was first built it had 155 across the board. To tell you the truth i havent checked it since.
CG puller
03-03-2006 07:46:19
I built a 3 9/16 bore H. It had 125 pressure until it was broken in. Be patient and run it a few more hours. Mine now has 175-180. Head shaved 100 thousandths. Look in a spark plug hole and see if cylinder wall still has hone marks. Hope this helps.
CG puller
03-03-2006 07:46:07
Drew
03-01-2006 19:37:02
Your camshaft profile and how it is timed can effect your cranking compression. If your camshaft has a bunch of overlap, this may be attributing to your lower cranking compression readings.
jhb
03-01-2006 19:22:26
Did a H without sleeves and 3 9/16 IH pistons, shaved the head .035 and built wrist pin bushings real close to specs and got 165# straight through. Runs good with 350 manifold and M carb at stock rpms.
FatRedneck
03-03-2006 05:49:16
 Re: FARMALL H COMPRESSION in reply to jhb, 03-01-2006 19:22:26
can you give me some details on your H i'm building one myself and need a little guidance?
Andrew Z
03-01-2006 16:54:44
Yea, that seems alittle low, Our Super H, has the 3 9/16" pistons and its got 145lbs of compression. The only thing I can say is did you check your valves to make sure there seating nice and tight. Or maybe it needs to be run more to seat the rings better? Andrew
Kevin
03-01-2006 14:06:19
To me what you got sounds about right. Want more power? Stroke it.
