Farmall tractors with Turbos
Brad in WI
03-02-2006 02:56:11
If any of you guys/gals are pulling a Farmall with a turbo, where do you have the oil lines running to. Where does the pressure line to "feed" the turbo come from and then where do you dump the oil back into the sump. Also what size lines are you using. Thanks for all the replys in advance.
Brad
minnesota red
03-02-2006 06:01:28
 Re: Farmall tractors with Turbos in reply to Brad in WI, 03-02-2006 02:56:11
oil comes from the filter base on most engines,a 3/8 line is more than enough.
normally returns through a threaded hole in the block,depends on the engine,normally a 1 inch line for the return.
