Compression--c.i.d. help on 41 M
Dale Lee
03-23-2002 06:15:36
I have a 41 M bored out to 4.310 with dennys aries pistons and standard stroke I was wandering what the compression ratio and c.i.d.would be. thanks a lot for any help. Dale Lee
randy hall
03-23-2002 20:43:57
 Re: compression--c.i.d. help on 41 M in reply to Dale Lee, 03-23-2002 06:15:36
i like to use the old fashioned formula i learned studying for me steam engineers license, bore times bore times .7854 times stroke times number of cylinders. ask denny what your compression ratio is.
AC PULLER
03-23-2002 19:33:45
306 CID....TAKE THE BORE, DIVIDE BY 2, SQUARE THAT, THEN MULTIPLY BY 3.14. THEN MULTIPLY BY THE STROKE AND MULTIIPLY THAT BY THE NUMBER OF CYLINDERS. ANTIQUETRACTORPULLING.COM HAS A RPM CHART AND A FILL IN THE BLANK FOR CID. HOPE THIS HELPS.
Tim
03-23-2002 17:57:44
Go to this web site and fill in the blanks Link
>Link
chris
03-23-2002 07:01:37
I come up with 284.2 ci from 255.5 originally but thats my math, check out where Bonanza said and let us know I took 4.31 x 3.1416x5.25x4=284.2 this formula works for me: bore x pie x stroke x # of cylinders
also take ci divide by 61.02 and round up to tenths that gives liters. I found this in a book years ago comes in handy
Bonanza78
03-23-2002 06:27:15
I put this up before, but it really helps
www.angelfire.com/fl/procrastination/motor.html
It gives both CID and compression, I used it to figure out what my chrysler 300 had.
Good Luck
Jason
Tim
03-23-2002 17:59:08
 Re: Re: compression--c.i.d. help on 41 M in reply to Bonanza78, 03-23-2002 06:27:15
Sorry, i should have read your post before i replied.
