????? on weight setup on W-9
Texas Red
03-23-2002 13:18:39
My W-9 is stock all the way. I have 600 lbs wheel weights on rear wheels. I have 800 lbs suitecase weights mounted on the platform under the seat. she now weighs 7940 lbs with me on it. How does this setup sound to the guys that knows a lot more than i do about the w-9s. Do you think the front will try to come off the ground enough to transfer the load to the rear wheels . Thanks for any and all Help. I will be pulling it for the first time the end of April at our show in Graham, Texas on the last weekend. Texas Red
Texas Red
03-24-2002 09:06:27
 Re: ????? on weight setup on W-9 in reply to Texas Red, 03-23-2002 13:18:39
Thanks for the help, I am trying to get it ready for the pull and i have nothing big enough to test the ballance on it.I can get it on the scales and do the math and then move two of the 100lb weights to the front. Would this be correct Thanks again for the help ( because i need all i can get) TR
John B.
03-24-2002 05:59:42
The next step is to weigh the tractor. Your front axel wt. should be around 2700 & the rear axel wt.around 5200. I would make provisions to move the hangons forward or back if needed.
John Banet
03-23-2002 19:42:06
A good place to start on most tractors is 65% on the rear wheels & 35% on the front. This is with a 18" high drawbar.
John Banet
03-23-2002 19:33:43
When pulling on a standard drawbar at 18" high a good place to start is 65% of your total weight on the rear wheels & 35% on the front. This will give you a good starting point for most tractors.
buckmaster700
03-24-2002 05:32:56
 Re: Re: ????? on weight setup on W-9 in reply to John Banet, 03-23-2002 19:33:43
you will need a minimum of 200 # on the front
