ChadS
03-15-2006 07:45:06
Re: Farmall M, what can I do ??? in reply to Flogger, 03-14-2006 13:43:01
If the compression is at 100-125psi @ cranking speed, well, your pretty much stock. You should go with an inframe overhaul with higher compression pistons. You can do that for under 500, thats the best money spent, then start looking at the cyl head, maybe machining some off to increase compression, or lightly port and polish, or look for a 450 gasser head. put in a 450 cam too. That will make a good M with bolt on parts. You can add from there, build the carb and ignition, governor work, roller rockers, etc etc. You might see 65 hp with that setup and have less than 1000 in the whole thing if the head is in good shape. If your compression is over 150 psi, then you have something to work with,, you can rejet the carb, maybe change the venturi, rebuild the distributor, check all your adjustments, valve lash, point gaps, or plug gaps. You might find 5 hp, you might find 10hp. run a compression test, under 150 psi, think rebuild, over 150, think of tuning on a dyno. ChadS
