Cracked head
Ben Rauls
03-15-2006 08:44:48
I had my head at the machine shop for a valve job, and resurface, he said there are 5 little cracks in it. I have heard these old IH heads are always cracked, but he said theres a good chance it will leak, now he builds stock car engines he said he really doesnt have a lot of experence with old engines. Do i send it out to someone different? I dont want to put this head on and have it leak. Help
Ben
superih
03-16-2006 07:26:19
 Re: Cracked head in reply to Ben Rauls, 03-15-2006 08:44:48
K&W block sealer works awsume. make sure to follow the directions. Had a cracked/leaking water head on a pulling M that had too much work into to just start over. K&W fixed it
AC
03-16-2006 14:55:58
 Re: Cracked head in reply to superih, 03-16-2006 07:26:19
Moroso Ceramiseal works far better than anything I have ever used...Available at Lane Automotive and other places like Summit and Jegs
B BARENIE
03-16-2006 05:56:13
MOST MACHINE SHOPS ARE OVER CRITICAL ON THESE FINE LINE CRACKS ! aS THE VERY LAST POST, HAVE IT PRESSURE CHECKED, IF IT WILL HOLD AIR FOR 24 HOURS, SHOULD BE NO PROBLEM HOLDING WATER !
ARE THE CRACKES BETWEEN VALVE SEATS?
Ben Rauls
03-17-2006 00:16:43
 Re: Cracked head in reply to B BARENIE, 03-16-2006 05:56:13
Crack in the combustion chamber that goes just to the edge of the seat, then a crack by a coolant passage on the mating surface, accually 2 combustion chamber are like that and 2 water passages
Ken B.
03-15-2006 16:02:21
if it's an M there is a head on ebay cheep worth the look
yorkie
03-15-2006 14:52:26
just put a can of k&w block sealer in i did it in my allis with no side effects
DBoll
03-15-2006 11:52:11
Have them pressure check it.
brandonf
03-17-2006 20:50:10
 Re: Cracked head in reply to DBoll, 03-15-2006 11:52:11
why not jsut pin the crack that is very easy?
