14.9x38 vs. 15.5x38
super_m
03-15-2006 15:06:15
i know this has been discussed a lot,but what would be better for low gear pulling on a sandy track with a super m. 14.9x38 firestone 45 degreee champion ground grips, or 15.5x38 goodyear 23 degree power tourqes on 15 inch rims?how much more power does it take to turn 14.9's?
B Barenie
03-15-2006 19:00:39
 Re: 14.9x38 vs. 15.5x38 in reply to super_m, 03-15-2006 15:06:15
THE 14.9 OVER THE 15.5, THROW AWAY THE 15" RIM ON THE 15.5'S IF YOU HAVE TO PULLTHAT TIRE !
STAY WITH THE MANUFACTURES RIM WIDTH , PERIOD !
IF YOU COULD FIND A PAIR OF CO-OP 30 DEGREE BAR 14.9-38'S, THAT WOULD BE THE ULTIMATE BET !
I/M VERY MUCH SOLD ON THE 30 DEGREE BAR 0N ALL TRACK CONDITION'S !
770
03-15-2006 17:49:20
Apples to apples, 14.9's will usually out do 15.5's every time. Much larger footprint. 45 degree tires most people say will do good only on a loose or dirt/sand track. I use 45 degree all the time. HOWEVER, 23 degree tires are the most popular and seem to hook well. My 2 cents.
wolfman
03-15-2006 16:28:11
14.9-38's give you a bit larger "contact patch" to the ground. 15.5's with their short sidewall give you much less of the dozer affect -fever bars on the ground. Tractors with 15.5's usually don't do so well in say dead weight pulls as do those with 14.9's or better yet 16.9's. You'd need 70-80 hp for 16.9's.
Mike Aylward
03-15-2006 16:25:36
Super M, the Goodyear tires are actually about 45 degrees as well. The "squiggly" bars are somewhat deceiving. If those were the only choices you had I would probably pick the Firestones due to their better carcass quality. A true 23 degree Firestone would be much better, or even a 30 degree BFG. My choice of the two you mentioned would be "none of the above". My humble opinion. Mike
