450 lp head on M
cs
03-24-2002 06:10:23
I have purchased a 450 lp head to put on my super M. what would be a good setup to run with the lp head. will flat top pistons be the route to go or will the M&W make more power. I also have a cam and intake off a 450 lp and plan on going with that. Any ideas you may have to get more hp will be greatly appreaciated. Thanks cs
randy hall
03-24-2002 20:49:52
 Re: 450 lp head on M in reply to cs, 03-24-2002 06:10:23
you are on the right track we have one set up like that with m&w pistons. use cam 2 gas from the sprint car boys.
farmall flogger
03-24-2002 18:58:09
There's not a whole lot of room with that LP head. I had one on an M with the 4 1/8 sealed power kit. This piston has a small step on half the piston head. Cranking psi was around 190. At that you need pretty good fuel. If you run a higher domed piston just make sure you have clearance. The cam and intake sound pretty good. You might wanna have the manifold and head port matched. Good luck!
BUD BARENIE
04-03-2002 04:47:38
 Re: Re: 450 lp head on M in reply to farmall flogger, 03-24-2002 18:58:09
how did you find an lp head ? big bucks, need a good cam send it to bullet cams in missisippi !!
carb will need work !!! be carefull on all that compression !!! just installed a pair of used tisco domed comfortmatic pistons with an 8777 distilate head !!! to much compression at low rpm is not good !!!! i've never bought anything from dennys carb, but i like their dome configuration alot better than the m@w. also watch the throttle shaft between carb and govenor, sometimes they break just had it happen on new overhaul. thank god i was on the tractor
