Extended rockers
Donnie T
03-21-2006 17:28:16
What kind, if any, power increases do you recieve from installing a set of these? Thanks for the help.
BBarenie
03-21-2006 19:16:57
 Re: Extended rockers in reply to Donnie T, 03-21-2006 17:28:16
Performance rockers will not help much and will probably cut mid to low end torque !
I refuse to advertise for any company and or individual, but in your situation, because of what I no, there is one individual, who can increase engine performance, staying at the cubes your already at !
What i'm talking about is the mid to low end torque curve !
I would ask that you call Gary Baker at # 734-678-9688
Don't waste his time, just do the business
You will not be disappointed !
bud barenie
Donnie T
03-21-2006 17:30:43
These are for a Farmall M at 300 cubes. Have a good reground cam. Running about 75hp know. Looking for something to get me about 80+. Sorry for the 2 posts. Got excited and closed the first one out.
Drew
03-21-2006 19:10:09
 Re: Extended rockers in reply to Donnie T, 03-21-2006 17:30:43
The rockers will probably get you to 80hp. The rockers do not replace a reground camshaft and a reground camshaft does not replace the rockers. Depending on what your camshaft is, you will probably want a split ratio setup(1.9 intake and 1.7 exhaust) The rockers add 'area under the curve'--they open the valve quicker and increase duration at .050, .100, .200 lifts, etc. w/o increasing total overlap.
I have heard about a 281" M engine that gained 7hp by just adding the rocker arms.
CrazyAllis Kurt Hamel
03-21-2006 18:54:16
If your cam is ground correctly for the stock rocker arm ratio you will see no gains and can possibly even a slight loss.If you do see a significant gain your cam was not correctly mached to your engine specs.These seem to work best as a way to gain power on stock cams, but I feel it is a pretty poor power per dollar investment as the rockers cost more than regrinding a cam costs.
Joshin Around
03-23-2006 09:25:50
 Re: Extended rockers in reply to CrazyAllis Kurt Hamel, 03-21-2006 18:54:16
I would say that it would help it. It would make the valve open farther thus allowing more air into the cylinder. The low end torque I dont know about if you are running higher rpms I dont think that it would matter.
