Any one ever used an overbore kit in an Allis WD?
Kurt
03-24-2002 23:12:02
I found an 1/8 overbore kit for my WD and I just wondered if anyones had a problem with over heating or cracking. Also does anyone know if they make a perfomance cam for one? I'm building the old girl up, I just purchased a WD45 crank. I just want a little extra a*% behind her.
KB
03-29-2002 05:47:22
 Re: Any one ever used an overbore kit in an Allis WD? in reply to Kurt , 03-24-2002 23:12:02
If you run the WD pistons with a 45 crank your compression is going to be too high.... you probably want to go with d-17 4 1/8 or 175 4 inch pistons. The 175 pistons are higher compression but it is about the same as the 4 1/8 bore with lower compression. Either way you should gain about 6 horse power from the pistons. I don't know exactly what the extra 1/2 inch of stroke from the 45 crank will gain you but that is probably going to help more. They are reliable with the 4 1/8 kit in them. The blocks crack either way :)
Ron
03-25-2002 21:39:42
I can tell you that 7.2 to 1 Compression is plenty in a WD-45 that will work in the field... Even with 7.2 you can't pull it down very far or it will rattle...
Ron
03-25-2002 16:46:29
It isn't the Big Bore, it is just the result of so many times AC bored, and stroked the block...!!! The webs at the bottom of the block between the 1-2, and 3-4 cylinders are extremely narrow... Cracks are to be expected there, and the block can be "Pinned", or even resistance-welded and pinned... be sure to check...if you don't have a crack....it is unusual...
LL
03-25-2002 12:21:09
About 1/3 of the engines that I've had apart with 1/8 overbore have had at least one cracked cylinder. Get sleeve and piston set for WD-45 at AGCO dealer. They have good competetive prices and the 45 kit now comes with D-17 pistons instead of the old 45 ones. It is compression that really makes the power not a small increment of 1/8" bore anyway.
Irv
03-25-2002 16:32:43
 Re: Re: Any one ever used an overbore kit in an Allis WD? in reply to LL, 03-25-2002 12:21:09
Go with Agco piston for a gas model 175. This
will give you 8.2 to 1 comp ratio. WD-45 pistons
are 6.5 tp 1.
Craig
03-25-2002 09:43:17
it will work but wd pistons on a 45 crank is a lot of comp. use a camshaft out of a 175 gas. also try gov. weights out of a gleaner e combine.hammer down!!
