Farmall M Head Milling
Johnny Mac
03-25-2002 11:48:43
I have a Farmall "M" with a 8574 head, new set of Firecraters & 450G cam. I would like to mill the head .100. Will milling it cause detonation problems or require me to use slower burning fuel? Thanks!
Dale13
03-26-2002 14:00:25
 Re: Farmall M Head Milling in reply to Johnny Mac, 03-25-2002 11:48:43
Don't know for sure about the 8574 head but I took.180 off a 8060 headand have had no detonation probs even on regular.Thats with M&W 4.125 #76 pistons.Put race gas in it and bump the timing up to about 10 and it runs nice there too!
reddog
03-26-2002 10:00:34
You are pushing it,do you have to dyno tractors where you pull?If it gets hot overheated much,the cracks will come!
randy hall
03-25-2002 21:34:54
you could gain a couple more hp if you get a 450 gas head and you would have no problem burning pump gas. these haeds breathe a lot better and have a 30 cc smaller combustion chamber. good luck with your m, randy
Jeremey
03-25-2002 18:55:04
I have a M with the gas head and took off .125 with no problems.
Chuck M
03-26-2002 15:45:57
 Re: Re: Farmall M Head Milling in reply to Jeremey, 03-25-2002 18:55:04
when you cut the head down do you shim up the rockers? can they adjusted without shiming?
Chuck M
03-26-2002 15:45:19
Chuck M
03-26-2002 15:48:00
 Re: Re: Re: Farmall M Head Milling in reply to Chuck M, 03-26-2002 15:45:19
I am using 450 gas head. sorry on double post.
Deere Puller
03-25-2002 18:16:51
I am doing the same exact thing - People have told me that there will not be a problem. I was to understand that the 450 LP will cause detonation problems, but not the M Gas w/ light shaving.
