John Deere 'G' or Oliver 880
50man
03-25-2002 18:53:47
Looking for a good (sort of stock...ha ha)pulling tractor...thinking of either a John Deere 'G' or an 880 Oliver.....any pros or cons of either?
deeres are for slow races
03-27-2002 12:04:40
 Re: John Deere 'G' or Oliver 880 in reply to 50man, 03-25-2002 18:53:47
Take the deere to a slow race and pull the oliver
Tyler
03-27-2002 22:15:57
 Re: Re: John Deere 'G' or Oliver 880 in reply to deeres are for slow races, 03-27-2002 12:04:40
G's were antique when they were new.
A Man
03-27-2002 19:18:36
the deeres pull the olivers to the shows ha ha
farmall flogger
03-27-2002 09:16:30
Reckon maybe you Deere and Oliver boys can pull while us farmall boys are gettin a hamburger and piece of pie. That a way maybe we won't miss too much.
50man
03-26-2002 15:48:24
Thanks for all of your input(....well most of you anyway!)
JNolan
03-26-2002 06:40:37
This brings back old memories. Two diff 880,s that pulled back in late 70,s early 80,s. My 48 G was basically stock 1st gear 6000 lbs. One 880 from West Branch Mi. tried and tried and couldn,t do it until one year I brought my G straight from the woods to the pull and she coughed a couple times and he got me by an inch. The other one from central Mi. was tough and did his share of winning. They both had a big HP advantage and were spit polished before every pull. Funny thing was they always were asking where a G could be bought or if I knew where there was one.
A.P.
03-26-2002 09:33:18
 Re: Re: John Deere 'G' or Oliver 880 in reply to JNolan, 03-26-2002 06:40:37
With luck I may be able to try my 88 standard against your "G" a couple of times this summer Jim. ;-) Now if I can just find a good set of tires...
Take care,
A.P.
Color Blind
03-26-2002 06:08:44
If you are talking basically stock tractors...I would take the G for soft tracks and the 880 for hard "power" tracks. The 880 can pull competitively over a wider weight range than the G in stock classes...But if you put alot of $$ in the G engine; it will probably beat the Oliver most of the time. I respect the qualities of both of these tractors! For smoothness, power and comfort the 880. For putting the power to the ground in soft conditions the G.
EFV
03-26-2002 04:36:23
What type of pulling? Transfer or dead weight?
What division or weight classes? Your question
is too vague to give a useful answer.
Andy
03-25-2002 20:47:00
I think a G puts power to the ground better in a stock rpm pull but the screamin olivers and molines are hard to beat in open class.
A Man
03-25-2002 20:43:33
G will out pull an oliver most of the time i dont care if it start an war that is a fact jack
burns
03-25-2002 19:19:15
Not real familar with the 880 but I have to suggest going with the G. There is nothing like a good running "stock" G.
Hopefully the post doesn't start another brand war.
50man
03-25-2002 19:31:20
 Re: Re: John Deere 'G' or Oliver 880 in reply to burns, 03-25-2002 19:19:15
Thanks for your insight-I had a feeling you might suggest a G! By the way you seem to be quite knowledgable on Deeres. I had my 50 rebuilt a few years ago and stupid me not thinking I might pull with it put it pretty much back stock (except for .090 over alum. pistons) I wish now that when I had the head off I would have done some work to that to bump up the compression to gain some HP. Thinking of it now.... any ideas on what and how much? What do they do when they port and polish a head?
Jack
03-26-2002 05:07:10
 Re: Re: Re: John Deere 'G' or Oliver 880 in reply to 50man, 03-25-2002 19:31:20
Hey 50Man pull the plugs and pull a compression check and let us know what it is on your 50,if you don't mind.I have a friend of mine that has a 54 50 and it has 125 psi per hole and with 12.4 38 tires he took M's G's and some A's on the right tracks and never choked with the creeper gear.He has had more fun with that one than all his others.He shocked me and others with it in the 5500lb class at local fair pulls.Later-Jack.
50man
03-26-2002 15:52:59
 Re: Re: Re: Re: John Deere 'G' or Oliver 880 in reply to Jack, 03-26-2002 05:07:10
I'll do that as soon as I get a chance and let you know.Did your friend do anything else to the motor?
Jack
03-27-2002 08:15:28
 Re: Re: Re: Re: Re: John Deere 'G' or Oliver 880 in reply to 50man, 03-26-2002 15:52:59
He bought his 50 like it is.His has blowby but pulls very good.Later Jack
burns
03-26-2002 01:44:40
I've never messed with a 50 so I'm not sure what would be a safe amount to mill off of the head. I'm sure someone on this board will know. As far as the port/polish, basically you are enlarging the intake/exhaust ports to allow for more CFM/air exchange. Also, you can mess around a little with the valve bowl/short side radius to help with the air exchange. Let the breathing begin, 8^)
if U want to win, drop the G JD idea!!!
03-25-2002 19:49:53
Family Tradition
03-29-2002 05:38:08
 Re: Re: Re: Re: John Deere 'G' or Oliver 880 in reply to if U want to win, drop the G JD idea!!!, 03-25-2002 19:49:53
If you want cheap HP, get a moline U, UB, or G! They are the cheapest high HP tractor you can build!
oldtimer
03-26-2002 17:24:40
go with the "G", win or lose you will love the sound of the old girl "putting the power to the ground," and I think the spectaters, would rather watch a "G" lose a pull than watch a oliver win, just a fact,jack
Mike F
03-27-2002 19:28:38
 Re: Re: Re: Re: Re: John Deere 'G' or Oliver 880 in reply to oldtimer, 03-26-2002 17:24:40
I was always told to listen very carefully to the "oldtimers" Good advice!
Guess again
03-26-2002 18:18:07
We don't like watching them slow powerless john deeres. We want to watch the tractors with power speed down the track. Put the JD in a parade not in a pull.
Hope you dont want to win!!
03-26-2002 12:22:17
If you buy a G you are taking a big risk, I out pull stock Gs with my 88 all the time. If you hop up a G it is just going to break in half! I didnt see Bill Bears old 880 break in half though!
art
03-26-2002 02:28:26
At stock rpms in 6500- 7500- 8500 I will run my 88 against any G anytime. I won't win them all but I'll take my chances. I love pulling against G's that put the power to the ground better and out pull the screamin olivers. Art
