Allis Chalmers WC
Joshin Around
04-06-2006 06:09:42
Does anybody know how to check stroke for a Allis engine without taking the head off? I thought about trying to get a straw down thru the spark plug hole and checking it that way but I am having trouble getting it in the head .. the engine has the plate on the side of it like a WD block but it has the WD45 head intake and carb on it. Im hopeing that it has the 4 1/2 stroke in it.
Thanks,
70puller
04-13-2006 14:44:44
 Re: Allis Chalmers WC in reply to Joshin Around, 04-06-2006 06:09:42
why couldn't you stick a wire in a plug hole & turn the engine over & measure it?
Kurt-Allis Puller
04-07-2006 20:22:50
That is not just a WD45 head - Its the taller one your speaking of right? They were on many of the WD's. The only difference is they positioned the hole for the spark plug to be in the center for better combustion. If the serial # on the side of the block starts with the letter "U", then its a WD but if it starts with "AM" its a WD45. Email me with any questions - Im running a couple WD's and one with 38's and can maybe give some pointers if you building.
CA+
04-06-2006 09:26:33
PULL OIL PAN CHECK CASTING # 4.5 STROKE IS 226 ON
THE LAST 3 OF NUMBER
Joshin Around
04-07-2006 08:54:24
 Re: Allis Chalmers WC in reply to CA+, 04-06-2006 09:26:33
I am not for sure that the crank that is in it came with the engine that is in the tractor or if someone has changed the crank.
John (MO)
04-06-2006 06:40:25
You could also do it from the bottom end by taking the pan off.
