Hey t.r.y.
CLIFF S
04-06-2006 07:23:35
What did you think of Buffalo Valley? Do you Guys think you will be back up for some of other Pulls? Cliff
CLIFF S
04-08-2006 05:48:36
 Re: Hey t.r.y. in reply to CLIFF S, 04-06-2006 07:23:35
I would like to come down for that one BUT i may be tied up, We been working at Trout runs New track on the Saturdays and thats a week before our first pull So well See!!I looked at the Rules and i see that the drawbar hight is at 18", Do thet alow any percentage over the weight with driver? How many Hooks per tractor? If we Don't Make this one We are Thinking of coming down to Muddy Run in July
t.r.y.
04-10-2006 05:45:03
 Re: Hey t.r.y. in reply to CLIFF S, 04-08-2006 05:48:36
as far as I know as many hooks as you want except for the reunion pull. Muddy runs a real good one. I'm pretty sure they don't have any allowance. but not 100%.
t.r.y.
04-06-2006 08:33:18
hows it going?? It was a pretty nice pull. Not a big fan of the sled or the rules but it was fun. The thing I didn't like much about the rules is that one sounded like a lot of guys were running way more than stock plus 10% two is the tire size rule kind of stinks. We set up for one size over stock pulls. and that makes it hard when every body else is running bigger. the buffalo valley track and sled you could say is made for big tires and power and weight in the back/middle. our pulls around here are more about keeping them balanced. the farmall c did good for the first time out. I think 4th in 3000 6th in 3500 we'll make a couple changes and get it going better. my oliver is built to pull 4000 and 4500. 5000 is a little heavy for it. if I had the 14.9 or 15.5 would have made a bigg difference. keep in touch about up coming pulls it was nice meeting you and talking with you. take care Trent 717 578 2572
CLIFF S
04-07-2006 09:48:52
 Re: Hey t.r.y. in reply to t.r.y., 04-06-2006 08:33:18
I am Glad you guys Came and had a good time, and yout Right about the RPMs ButEvery since they put a speed limit of 3.5 on they threw out the RPMs unofficaly and that BV sled is Heavy! and hard to start for little tractors, The Card i gave you on Trout Run and at Nisbet would be more like the the kind of pulling you guys do with ballance and a long chain and at nisbet they would Tack you for over 10% and the oliver would feel at home over 5000lbs class because we have a hard time hooking up Super Cs less than 4000lbs and at nisbet you can pull as many times as you want and both of these places have a class for Non Altered Tires like you guys run and the sleds start easy compared to BV and Hughsville (4/23/06)is the place for your Oliver 77 and you can start at 4000 or less But they also have a 3.5 mph speed limit But with 20% over RPMS, And all drawbar spects here are the same,Are you guys going to Rough and Tumble Pull? I will keep you informed Cliff
t.r.y.
04-07-2006 12:22:48
 Re: Hey t.r.y. in reply to CLIFF S, 04-07-2006 09:48:52
Yeah were going to rough and tumble. thats a pretty nice pull. You'all should come down for that one. You can go on there web site for rules or I can email them to you.
