450 STROKER
450 puller
04-18-2006 19:14:42
How do u get a 7.25 inch stroker crank to swing past the camshaft in a M-450 block with H rods in it. Help would be great
B BARENIE
04-18-2006 19:29:44
 Re: 450 STROKER in reply to 450 puller, 04-18-2006 19:14:42
You will have to notch the cam. There is no way you can put it in a lathe an spin it.
Install the cam, mark contact point, and start the grind process.
I would recommend custom rods !
If you need a finished cam, with the rite grind, based on cubes and compression !
please call # 734.678.9688
have a good evening
