8060 DC head vs.450 gas head
super_m
05-11-2006 18:29:40
i have a super m with a 8060 head that has been lightly milled and ported.im getting a 450 gas head and am going to have it ported and milled.how much of a hp increase should i get out of the 450 gas head.also which rocker arm assembly would be better,the one on the 8060 or the ones off of the 450 head?
SM-53
05-12-2006 03:32:48
 Re: 8060 DC head vs.450 gas head in reply to super_m, 05-11-2006 18:29:40
You will need to add a breather to the sm valve cover, the 450 gas head breathes out the top of the cover, not the back of the head. Horse power increase should be good for a couple. Rockers, I'm almost possitive, the same.
If you want to really inhance performance, for pulling and not break your budget, send the head and manifold up to Gary Baker. ph # 734.678.9688
He does some head and manifold work, that will really increase low end torque. Stock or big cubes!
Do not shave to much off the head, compression increase is not enough to warrant destroying a good casting.
