Hey G Taylor
Troy
03-29-2002 08:15:08
I thought that you couldn't mix gas and Methol alcohol, that it would separate out? Just wondering, it would be alot cheaper then buying the $5.00 a gallon stuff.
G Taylor
03-29-2002 14:02:40
 Re: Hey G Taylor in reply to Troy, 03-29-2002 08:15:08
Right at the 10% alcohol point the two comonents will settle out, just like milk & cream if allowed to sit. Can't hurt to mix a test batch & watch what it does. Depends on temperature as well. So either mix in more or less & keep it stirred prior to starting. It's cheap & easy HP,octane & SG control. More than 10% methyl will start to strip rust off the steel tank & attack componets over time. The wee squirt of alcohol is mostly intended to lighten a heavy batch of gas. Xylene or toulene blending with premium pump gas seems to be a well kept secret. Of course 100LL aviation fuel is fairly cheap & handy. It's designed for combustion in low rpm long stroke engines such as radial airplane engines & tractors. If the engine detonates on 100LL it's some kind of monster or there is something wrong. "Cam what ever" gas is intended for 9000rpm small blocks.
Troy
03-30-2002 07:35:53
 Re: Re: Hey G Taylor in reply to G Taylor , 03-29-2002 14:02:40
Back in the late 70's we were told that av-gas was the ticket. We ran it in both of our tractors ( U Allis and BR JD) and the only thing noticed was after pulling and letting them sit and cool down you could hardly crank the BR over and the U Allis we had to pull to get started! After that a little 2 stroke oil took care of that problem. Later our supplier switched planes and the new one burned regular gas, back to 92 octane. Thanks for the info G Taylor.
