C Pedelstal and 460 hubs
FarmallHPuller16
05-24-2006 11:33:14
Will 460 hubs fit on a C pedelstal? I thought thats what i heard. I want to put it under a H.
super_m
05-24-2006 19:08:24
 Re: C Pedelstal and 460 hubs in reply to FarmallHPuller16, 05-24-2006 11:33:14
is that the whole assembly from the pedastol to the top part where the steering rod goes through?would it bolt on a super m to?
Bencie
05-24-2006 20:16:26
 Re: C Pedelstal and 460 hubs in reply to super_m, 05-24-2006 19:08:24
Your pedistal bolts to the bottom of the steering post. No it doesn't bolt right up, the bolt patterns are different, but you can pull the steering shaft down out, build the top around the bolt holes with weld, cuz its tapered, and grind it flat again and redrill it. Your original bolt pattern stays and you can put your original padistal back on if you wish.
Bencie
05-24-2006 14:23:23
Not sure if 460 hubs will work. Need to check bearing & race #"s. A pedistal off of a 340 has 6 bolt hubs & the same bolt pattern on top as the "C". I think total weight with 15X3 rims & 400X15 firestones is around 60lbs.
