6-1/2 gas 70 overbore with a pressed in sleeve???
buickanddeere
05-30-2006 18:15:05
If most G 6-1/8" blocks can be bored to take a pressed in 6-1/2" dia sleeve. Will the 5-7/8" 70 gas block take a pressed in 6-1/2" bore pressed in sleeve? As for welding in monster bore 7" sleeves. Will sliver solder hold the sleeves in water tight or is nickle rod welding or furnace brazing required?
JDBert
05-31-2006 05:54:32
 Re: 6-1/2 gas 70 overbore with a pressed in sleeve in reply to buickanddeere, 05-30-2006 18:15:05
third party image
I've got 6.125's in mine and they are sleeved, at 6.5 there will be little to none left of the orginal block.
JDGnut
05-31-2006 05:43:45
I'll have to measure.. but I don't think there is going to be anything left of the orginal cylinder to hold the sleeve.. (6.5 OD sleeve).. If you are thinking 6.5 ID sleeve.. Its too big.. Not sure on the 70.. but it might be fun on the head gasket.. leave a lip on the sleeve.. and bore it like a power block.. put the pistons in from the bottom...
