Hitch for MM UTU
Brian W
03-31-2002 18:23:58
I have just purchased a 1947 MM UTU and I am in need of some ideas in fabricating a drawbar assy. that will give some vertical and lenth adjustment. Also can one remove the oilbath air cleaner and go with a dry type and still remain in a stock class?
Andy
04-01-2002 11:05:33
 Re: Hitch for MM UTU in reply to Brian W, 03-31-2002 18:23:58
You can take the rear platform off and make one with a notch cut out of it to hook closer to the axle. Save the old one in case you want it origanal someday. You could make a pulling drawbar that has an upward bend in it to get higher and keep the origanal incase you want to put it in the field,(and keep your front end down).
