14.9 tires - shorter than 38
mshultz
06-14-2006 11:13:24
I'm currently running 16.9 x 24 tires on a case C. I bought it that way, and it pulls pretty decent. Later this summer I will have a problem pulling a few places though, so I need to work on a different set-up eventually. Some rules read that you can go 13.6 x 38 or one size wider if you go shorter - So I'm looking for a tire that is 14.9 x ???? Is there such thing as a 14.9 x 34, or anything else between 24" & 34"? What were they on from factory - would like to know which junkyards to check out.
Thanks!
06-15-2006 23:44:37
 Re: 14.9 tires - shorter than 38 in reply to mshultz, 06-14-2006 11:13:24
I`m thinking f-20 wheels will interchange with your c if they are the same as a cc case,I like my 14x36 wards on mine, I can pull in the 4,ooo class.
Jim in OH
06-14-2006 12:32:19
Add to that list 34", 38" and 42".. Here are the sizes available from Firestone. the number to the right is the "Flat Plate Area" in square inches that is sometimes used to define the allowable tire size in the rules.  Generally speaking, larger diameter tires pull better, but there are exceptions... Jim
Tire size Area 8.3-24   63
  9.5-24   79
  9.5-24   79
  11.2-24   96
  11.2-24   96
  12.4-24   119
  12.4-24   119
  13.6-24   130
  13.6-24   130
  14.9-24   160
  14.9-24   160
  16.9-24   196
  13.6-26   141
  14.9-26   166
  16.9-26   206
  18.4-26   242
  18.4-26   242
  18.4-26   242
  12.4-28   126
  12.4-28   126
  13.6-28   145
  13.6-28   145
  14.9-28   170
  14.9-28   170
  14.9-28   170
  16.9-28   209
  16.9-28   209
  18.4-28   250
  16.9-30   216
  16.9-30   216
  18.4-30   258
  18.4-30   258
  23.1-30   383
  23.1-30   383
  16.9-34   229
  16.9-34   229
  18.4-34   284
  18.4-34   284
  9.5-36   95
  13.6-38   168
  13.6-38   168
  14.9-38   200
  14.9-38   200
  15.5-38   189
  15.5-38   189
  16.9-38   252
  16.9-38   252
  18.4-38   300
  18.4-38   300
  20.8-38   352
  9.5-42   100
  12.4-42   150
dej(JED)
06-14-2006 11:21:42
There are 26", 28", 30" and 32" tires currently being used on tractors. A 14.9 and a 16.9 tire are of pretty much the same height. I don't know what configuration of a wheel you have, so it is difficult to offer suggestions. Often wheels will interchange from one tractor to another. There are open center rims, 8 bolt hole tin rims,9 bolt hole tin rims, 10 bolt hole tin rims and even 6 bolt hole rims. I hope this adds to the confusion, but seriously I might be able to steer you in a direction, but I am not familiar with a Case C.
