MM U STROKER
U DUDE
04-01-2002 09:15:54
HOW FAR ARE THESE GUYS STOKING THERE MM U'S WE STROKED OURS .160 AND THEY SAID THATS ALL IT COULD GO W/OUT WELDING IT ANY COMMENTS PLEASE.
bill
04-02-2002 19:48:56
 Re: MM U STROKER in reply to U DUDE , 04-01-2002 09:15:54
getting it right includes no water leaks no compression leaks and something that is repairable. (replaceable sleeve) not to many people who do it this way
Glenn
04-03-2002 03:22:45
 Re: Re: MM U STROKER in reply to bill, 04-02-2002 19:48:56
Sure it is when you have something made for press in sleeves to start with
Turbine Dude
04-01-2002 18:11:16
How big can you go with 4and 5/8 bore jug? 5"or 5.25 ect how far can you go safely..... Makes me real curiouse and what do you mean by doing it right please explain Thanks Turbine Dude
Glenn
04-02-2002 03:38:26
 Re: Re: MM U STROKER in reply to Turbine Dude, 04-01-2002 18:11:16
Going to 7.5 on stroke, and 5.75 on bore . I think 6 is doable.I have some new block casting that will work if anyone is interested. Glenn
U dude
04-03-2002 10:32:53
 Re: Re: Re: MM U STROKER in reply to Glenn, 04-02-2002 03:38:26
i wanted to know how much luck everyones having with welded cranks. and how far there going.
MM
04-01-2002 15:17:56
Mines 7.5" Merfield in Iowa did it for $800. A friend has got 7.75 and 8" is possible.
Mike S
04-03-2002 16:09:53
 Re: Re: MM U STROKER in reply to MM, 04-01-2002 15:17:56
How much Horse power is your U making? Thanks, Mike
bill
04-01-2002 12:01:24
We stroke ours to 7 inch cost about 650 dollars. its the bore that tends to get expensive if you can find someone to do it right.
BG
04-01-2002 18:33:35
 Re: Re: MM U STROKER in reply to bill, 04-01-2002 12:01:24
Hey Bill were are you getting yours done for that kind of money?
BG
Andy
04-01-2002 11:00:51
You can drop a G crank in it,(6") Some guys stroke that to over 7",(not cheap)
