DT466 in a 560
farmall650
06-25-2006 18:13:32
anybody put a DT466 in a 560 how much trouble and what problems do I have to look forward to
I Know
06-26-2006 22:29:32
 Re: DT466 in a 560 in reply to farmall650, 06-25-2006 18:13:32
Theres a 560 in western MO running a DT414.
mshultz
06-26-2006 09:34:47
Bolts right up at the bellhousing - M through 1466 all have the same pattern.(not all but most). You'll need to adapt the flywheel (I recommend having a custom steel one made) that has the bolt pattern of the 466 crank and the ring gear of a 560. You'll need to figure the "depth" of the flywheel so that the ring gear ends up where it is supposed to on a 560. Assuming the starter from an 806D, etc. fits in the spot, it should bolt into the 3-bolt starter hole and turn over good. Everything else from there takes a lot of time, but mostly just figuring out how to make it functional - throttle linkage, side rails, steering, etc.
good luck.
D boll
06-26-2006 05:44:55
I have seen a IH 360 put into a 560, they had to widen the frame. This weekend I saw a 560 with a 354 Perkins installed, it fit real nice and I am sure it eliminated all the problems the IH 282dsl. is plagued with!
minnesota red
06-26-2006 11:48:54
 Re: DT466 in a 560 in reply to D boll, 06-26-2006 05:44:55
if you use a front engine cover off a truck you don't have to widen them.
farmall650
06-26-2006 17:28:49
 Re: DT466 in a 560 in reply to minnesota red, 06-26-2006 11:48:54
the motor I have came out of a early eightes truck who makes the steel flywheels
Super Lurker
06-26-2006 07:16:39
I have seen 2 or 3. Looked pretty much like a bolt-in. I'm sure there was more to it than that. Contact Bobby Hinton from Lewisport, Ky. He did the one's I saw and has advised on some others.
