Elec Fuel Pump
PGpower
06-30-2006 07:14:45
Going to order an electric fuel pump for my MM U. Found one that delivers 1.5psi to 4.0psi or another one that delivers 4.0psi to 8.0psi. Which one would be best? Thanks.
Eastcoast puller
07-06-2006 06:38:42
 Re: Elec Fuel Pump question in reply to PGpower, 06-30-2006 07:14:45
I tried an electric fuel pump for the same reason runnig out of fuel half way down the track on my M. MOLINE G. This was a low pressure pump abou 2-3 psi and it would always flood the carb. What are you guys doing to keep the fuel pump from over riding the float and neddle. thanks.
Turbos10
07-01-2006 20:15:08
 Re: Elec Fuel Pump in reply to PGpower, 06-30-2006 07:14:45
I agree with lamount on the pump and regulator for the most part, but you can find some good pumps with built in regulator. A holley red pump is a good example. It will hold 7psi and feed any antique tractor engine around.
Lamont
06-30-2006 12:24:17
I tried the 1.5 to 4.0 PSI and kept running out of fuel about 3/4 of the way down the track. A drag race driver explained it like this and it makes sense. When the pressure built up to 4.0 on the small pump, which would probably have been enough to run my tractor, the pump would shut off. The pressure would go down to about 1.5 PSI before the pump would pick back up, but it was too late and I would run out of fuel. I don"t know if this is what was happening or not, but he recommended using a pump that gave a continous pressure and put a regulator between it and the carb. I installed a Carter that delivers 12 PSI, but I run a Holley regulator and set it on 5.5. The guage reads a constant 5.5 PSI and I have had no more problems. Go for a heavier pump with a regulator and I think you"ll be very happy with the results.
