560 farmall weight
560bandit
07-21-2006 14:39:44
i have a 560 gas tri front with 16.9 38s full of calciem i was jus wonderin what do u think it will weight i really wanna try for the 7'500 and 9'500 farm stock class i know it prob cant get in the 5'500 with the water in the tires but is there nething eles i can do 2 get it lighter?
ny bill
07-22-2006 11:20:09
 Re: 560 farmall weight in reply to 560bandit, 07-21-2006 14:39:44
fwiw, my 560 diesel, 16.9x38 loaded tires, wf, fenders, ta, lpto, 1 set back weights, 200#driver, weighed 9700 when i had it weighed. way over what i was expecting.
jpl
07-21-2006 19:14:49
I have a 560 gas, with 15.5-38, no fast hitch and pto removed, about 5 gal calcium left in each tire. 3 gal fuel and driver weight of 235 and it weighs 5750. run 6000 up in farm stock, you cant balance the weight very good for 5500 class, better in higher classes. hope this helps you. went to 9 bolt hubs and wheels and it weighs 5530 now.
ejr-IA.
07-21-2006 15:27:11
With out fluid and with fast hitch and NF you should make 6500 thats with cast wheels on rear.
