H heads
Paint Don't Pu
07-24-2006 17:47:31
Is there a spec some where for a new H head so you can measure and know if a head has been plained? I want to plain my head but bought tractor used and have no history on it. Thanks PDP
Paint Don't Pull
07-24-2006 19:30:05
 Re: H heads in reply to Paint Don't Pull, 07-24-2006 17:47:31
I had a head gasket leaking,pulled the head used straight edge and it is slightly warped. I can stick .005 feeler gauge under straight edge in the middle. Itwas RED but is kinda faded. Pretty good running old "47 Farmall H. Thought I might plain the head .020 or .030. I"m not trying to go hog wild. PDP
mr.thinker
07-24-2006 19:39:27
 Re: H heads in reply to Paint Don't Pull, 07-24-2006 19:30:05
you should be fine to take off that'that way the jd guys can't give you any crap about bleeding green out of the head although i'm a jd guy i like them all.
Drew
07-24-2006 18:55:10
Mr. Thinker is right, dont waste your time wacking a bunch off the head. You arent going to gain a lot of power and if you ever did need to cut it back flat, you will still have material there to do so.
Pull Don't Paint
07-24-2006 18:35:59
Nice thoughts Thinker I like that. Check your piston clearances then see how much farther you can go.
mr.thinker
07-24-2006 18:08:36
kinda hard to tell????first find out if it red (farmall) or green (john deere), second if they run leave it alone, and third if you want a puller don't waste your time and money on either one.
Just Wrong
07-25-2006 07:08:18
 Re: H heads in reply to mr.thinker, 07-24-2006 18:08:36
Whoooa now. A rose by any other name is still a rose but there is only one "Mr. Thinker" and you are not him. Most all JD people know who the original Mr. Thinker is and you aint it.
