560 ???
redlinefever
07-27-2006 09:44:18
im tryin 2 get more rpms out of my 560 gas right now with the linkage adjusted and the gov screw all the way in it will turn something like 2'300 almost 24 i was told that the 615 combine had the same motor and turned 2'600rpms and made something like 88hp i was also told the if i take the gov off and add a few washers and then back the screw all the way out and start over takein it in can get me well over 3'000rpms is this true??
mr. thinker
07-27-2006 21:24:41
 Re: 560 ??? in reply to redlinefever , 07-27-2006 09:44:18
try spuring the mule a little harder! a good hickory stink might work? look at it this way, when she blows , scrape irons up!
Steve in OR
07-27-2006 18:55:24
The governor is off of my 560 and according to the newly installed tach it will peg my 8K rpm tach pulling in the 6000 lb class. I'm gonna have to stop pulling with the "stockers" (my decision). I'm also going to have to get a steel flywheel (although it might already have one, I need to split and see.) I am begining to see that I opened up a whole can of worms that is going to add up to my budget in a hurry.
Steve NWPTA
OU812
07-27-2006 20:28:55
 Re: 560 ??? in reply to Steve in OR, 07-27-2006 18:55:24
I hope you check the flywheel pronto before another hook,for your safety and the spectators.
Steve in OR
07-27-2006 20:51:58
 Re: 560 ??? in reply to OU812, 07-27-2006 20:28:55
It's in at my mechanics now.
Steve
ejr-IA.
07-27-2006 18:11:44
I used a 715 301 combine spring and gov. arond 2850.
