Farmall H needs more power
FarmallHPuller
08-05-2006 20:25:11
I am looking to get a little more power out of my Farmall H, but not sure which direction to go. I am basically stalling the tractor everytime if I am on a hard track. Right now I have a M carb, 300 intake and head, paper type air filter, electronic ignition, straight pipe, and custom agressive cam built by comp cams. Have the H overbore kit installed 3 7/16" bore. Also have installed a better governor spring to bring the RPMs up to around 2400. Has anyone tried a thinner copper head gasket for additional compression. Also has anyone had a port and polish done on the head and intake? Any other ideas or feedback would be appreciated.
FarmallHPuller
08-07-2006 15:42:42
 Re: Farmall H needs more power in reply to FarmallHPuller, 08-05-2006 20:25:11
No, We just installed the cam straight up. Comp supposable builds 4 degrees of advance into their cams. It runs really well though just not enough power.
jason460
08-07-2006 08:13:14
Did you degree the cam when you installed it. I know on some you need to retard the cam. But you may need to advance the cam if your tractor is lacking on the other end of the track. Hope this will give you a starting point.
