Hard block
dave h
04-04-2002 16:50:22
considering filling water jacket to top to help support the sleeves. Anyone done this ? will run water in the head.
super 88
04-05-2002 20:51:58
 Re: hard block in reply to dave h, 04-04-2002 16:50:22
what are you guys using to fill these blocks with an how hight do you fill them
RR
04-04-2002 18:38:18
Sure that's the way mine is and it is worry free. Just make sure you have the sleeves sized after the hard block has setup because it will move the walls around. Also it will need extra piston to wall clearance than normal because the sleeve cannot expand outward therefore it comes in with heat. Mines been that way for 10 years and haven't hurt a piston since I switched to synthetic oil 9 1/2 years ago. Level the block and pour it in then take a jitterbug sander at low air pressure to vibrate the air pockets out and level the filler. Hope this helps and good luck.
