2006 Morrow County Fair Pull Sept. 3 6:30p.m.
Adam Coleman
08-26-2006 05:44:57
Would like to invite you all to the pull.
2006 Morrow County Tractor Pull
Sunday, September 3, 2006
6:30 p.m. at the Grandstand
Adam Coleman (419) 295-4592
Weight Classes In Order Of Run:
Sled 1: 3500 4000 4500 5500 6500 7500 8500
Sled 2: 9000 9000 Open 10000 10000 Open 12500
12500 Open 14000
Sled 1 Prize Money 50% Payback
Sled 2 Prize Money 1st - $100 2nd - $75 3rd - $50
4th - $30 5th- $20
8 or less will pay places 1-3
Hook fee: $20.00, No Double Entries
Everyone pays at the gate.
RULES:
1. All drivers must be at least 18 years old.
2. Only Gas, Diesel, and LP Factory Equipped tractors
allowed.
3. No Funny Fuels, Nitrous, Alcohol, Water injection, or
Propane Injection Allowed.
4. All tractors are to run the Suggested High Idle for their
model with an allowed 20% over.
5. NO CUT or GROOMED Tires in any way, IF ALTERED NO
HOOKING.
6. Any Rubber Tire Size Allowed, Radials Welcome, NO
STEEL LUGS or Dual Wheels
7. Two wheel drive tractors only, however, front wheel assist
can pull as long as 4WD is disengaged.
8. Drawbars are not to be shorter than 18 inches from
center of axle to hitch point.
9. Drawbars are to be no higher than 20 inches from ground
to top of hitch point other than 3500 & 4000 18 inch max
height.
10. Hitches must be ridged in all directions.
11. No part of drawbar to be higher than hitch point.
12. Hitches must have a 3 inch opening and be made of at
least 1 inch diameter material.
13. Clevises are allowed as long as they are a twisted type
and comply with rule number 12. Except Open Classes
14. NO STRAIGHT CLEVISES ALLOWED.
15. Engines must be of stock appearance as well as cylinder
block, heads, and manifolds.
16. Single fuel pumps and/or injectors, carburators of
original manufacture and design ONLY.
17. NO AIRPLANE CARBS, military carbs or non agricultural
carbs allowed!
18. All Classes on SLED 1 are 5 mph.
19. All Classes on SLED 2 are 7 mph other than Open
Classes will have NO Speed Limit
20. Tractors entered in Any Open Classes CAN NOT run in
any MPH classes.
21. Speed will be monitored on sled and all pullers will be
allowed 2 beeps and the 3rd beep puller is D.Q.ed
22. Wheelie Bars are required in Open classes & recom
mended for all other.
23. No weight allowed past 12 feet from center of rear axle to
furthest point forward.
24. Rear weights are to be no further than 18 inches past
furthest point of rear tires
25. Rear weights are not to obstruct hitching ease to sled.
26. Any loss of any object from tractor while hooked to the
sled will result in a Disqualification.
27. Side shields allowed but must be easily removable.
28. All pullers pull at own risk to damages of their equipment.
29. Any or all damages are pullers responsibility not the
promoters.
30. All tractors must weigh in before hooking to sled and
once in staging area no changes maybe allowed without
reweighing.
31. No Riders and a Safe speed will be enforced in the pit
area.
32. Class Closed once the first puller of that class hooks to
the sled.
33. All pulls will start with a tighten chain. NO JERKING OF
THE SLED
34. Pullers must stay seated for the entire length of the pull,
no bouncing in the seat.
35. Hands must be on steering wheel, throttle, hand clutch,
and or hand brake for entire length of pull.
36. All drivers are allowed 2 tries to pass the 75 foot mark
once past no restarting.
37. Puller must pass 50 feet to qualify for premium except for
tie breakers or pull offs.
38. First puller of each class is the test puller with the option
to drop and come back in 3rd position.
39. $500.00 protest fee with Protester’s tractor inspected
first!
40. Judges and officials decisions are final... including
situations not covered in these rules.
41. No Drugs or Alcohol allowed before or during the pull.
42. Each tractor will be given a visual safety check. Any fluid
leaks or items that jeopardize safety will result in
disqualification.
43. Drivers are to watch the flagman once tractor is hooked to
sled. Flagman is in control.
Failure to follow his direction will result in disqualification.
44. Tractor (not sled) must stay within boundries or be
disqualified.
1066
08-26-2006 14:20:22
 Re: 2006 Morrow County Fair Pull Sept. 3 6:30p.m. in reply to Adam Coleman, 08-26-2006 05:44:57
I guess if you have to ask where the is Morrow Co. your not going anyhow.Thank You
Adam Coleman
08-27-2006 13:50:51
 Re: 2006 Morrow County Fair Pull Sept. 3 6:30p.m. in reply to 1066, 08-26-2006 14:20:22
Sorry, it is in Mt. Gilead Ohio. 45 miles North of Columbus.
jd b puller
08-26-2006 17:15:30
Mt. Gilead, Ohio (43338) It's a metropolis of about 3000 people, owning a tractor is required if you are in the county. Normally a pretty good turnout and good track.
