A john deere with 350 engine
Mike W J
08-28-2006 17:01:23
Does anyone have some pics Of an A with a 350 engine ? I seen one in a magazine a few years ago but don't remember where. I would also like to know What all had to be done to make it work. THANKS mike
styledaman
09-09-2006 10:55:50
 Re: A john deere with 350 engine in reply to Mike W J, 08-28-2006 17:01:23
here is an A that i have always liked.
http://johnnypopper.com/jdgifs/expo/V8A.jpg
Turbos10
09-04-2006 06:47:03
I would like to see a pic of this as well if anyone has one to post please put a link to it.
BushogPapa
08-29-2006 23:21:55
One Late Styled "A" regularly appears at the Delaware County fair, Ohio each year... What enables the change-over is that the crankshaft is removed, and a differential (ring & Pinion)is installed in it's place, with a machined shaft exiting either just the clutch-side, for the hand clutch to be used, or both sides..in this case, a set of locked spiders would be needed... Then, the engine is mounted and connected to the differential... The 350 GM V-8 Diesel makes a nice choice, too...!
BeeCad
08-28-2006 19:56:25
I saw a rough unstyled John Deere at the Portland IN show last Friday with what looked like an Olds 350 diesel engine in it. Don't know any more about it. I do have a picture that I can send to you if I can figure out how to do it.
Bruce
