Farmall cam timing
one or two teeth off?
Doug
04-05-2002 20:59:53
I've heard guys talk about installing the M-450 cam one or two teeth advanced. What purpose does this serve? Does it only help highly modified engines, or can a stock engine gain a few hp from this as well? Thanks.
BUD BARENIE
04-10-2002 04:02:38
 Re: Farmall cam timing - one or two teeth off? in reply to Doug, 04-05-2002 20:59:53
USE AN OFF-SETT KEY WAY INSTEAD !! NEVER EVER
JUMP TEETH TO MUCH ADVANCE OR RETARD !! A GOOD CAM GRIND WOULD WORK MUCH BETTER STRAIGHT UP
the tractor vet
04-05-2002 21:35:11
And offset key would work better , but ya need to degree the cam for best results.
Doug
04-06-2002 04:38:50
 Re: Re: Farmall cam timing - one or two teeth off? in reply to the tractor vet, 04-05-2002 21:35:11
Where can I find the degree specs?
NEW TOPULLING
04-10-2002 14:51:40
 Re: Re: Re: Farmall cam timing - one or two teeth off? in reply to Doug, 04-06-2002 04:38:50
THE DRAG STTRIP GUYS HAVEBEEN ADVANCING RADICAL CAMS FOR YEARS TO GAIN LOWEND.WILL 2 TO4 DEGREES IMPROVE BOTTOM END LUG ON STOCK CAM NEAR STOCK TRACTOR?WHAT IS THE DOWNSIDE?
