Model A
John
04-06-2002 09:35:31
Hi guys. I have a 48 model A I am currently rebuilding. I have purchased .045 oveer high compression pistons for the motor. I don't want to pull for competition but I'd like a little more power. Do you guys havve any ideas for some extra horsepower that doesn't cost tooo much? Thanks John
Ron
04-06-2002 11:03:58
 Re: Model A in reply to John, 04-06-2002 09:35:31
Be sure to check the governor adjustment on the throttle rod...it should "just" close the throttle...you want the governors to be "quick" to take a full load.....this makes a World of difference in how the 2-Cylinder tractors pull... Probably would not hurt to have the RPM's set at 1,oooRPM under load, rather than 975... PTO work will still require you to run at less than full throttle, tho...
A Man
04-06-2002 19:15:44
 Re: Re: Model A in reply to Ron, 04-06-2002 11:03:58
BE sure to go through the head and fix it right and shave the head it will help
jd tech
04-08-2002 15:02:03
 Re: Re: Re: Model A in reply to A Man, 04-06-2002 19:15:44
WHY NOT GET A JOHN DEERE 435. THEY ARE FACTORY EQUIPPED WITH GM DIESEL
A Man
04-10-2002 18:59:38
 Re: Re: Re: Re: Model A in reply to jd tech, 04-08-2002 15:02:03
which side are you one that would stupid ruin a good tractor with a general mess
