Continental 140 needs more grunt
240 jockey
09-24-2006 15:58:31
I have a tractor with a Continental F140 in it although it is supposed to have an F162. Since the blocks are the same, can I just bore it out and put the larger pistons in? What else can I do to give this old girl more power? If it had overhead valves I would mill the head to increase the compression but obviously that won't work on a flathead.
Ian Johnsen
09-25-2006 20:45:03
 Re: Continental 140 needs more grunt in reply to 240 jockey, 09-24-2006 15:58:31
You can mill the head down and get more compression as long as you check your valve clearance from the block to the top of combustion chamber. Have you converted the distributer to a Pertronix set up? You could also put some tie wire around all or most of the coils on your governor spring. This won't allow it to stretch an allow for more rpm. Get a direct clamp on K&N air filter vs the oil bath. Bore is the only difference between all three F series continentals. If you have a chance, go into the photo section and check out my turbocharged f162 in my '47 Massey Harris 20. I have done about all you can do to squeeze power out of one of those little flatheads.
