Farmall M vs. 620 John deere
budcjc.
10-10-2006 13:11:54
I know the 620 is rated for more power, But with a fresh stock rebuild in both tractors will the M stay with the 620 on the sled,..... thanks " Bud "
cousin_gary
10-16-2006 17:28:42
 Re: Farmall M vs. 620 John deere in reply to budcjc., 10-10-2006 13:11:54
That deere would be no match for the farmall M, even though a 620 is definitely in the super m class. Where I pull they gave up pulling 2cyl deeres 20 years ago.
Remember unless it is red leave it in the shed!!!
AGCO AVENGER
10-12-2006 18:49:33
Neither one has enough power to pull much if it is "Stock." Old MM's with a little parts swaping can beat them all including a Case 400.
Avenger
B-maniac
10-11-2006 19:14:24
Well,you've heard all the if's and's and what if's. The answer to your question,AS IT IS WORDED,is a very simple NO. Each tractor is what it is.
Flogger
10-11-2006 05:29:34
The "stock" 620 has the advantage of that 1.5 mph low gear. It'll usually pull 10,000 lbs plus on a good track. The "stock" M however has a much faster 2 5/8 mph low gear and much over 7000 lbs on a good track will usually give a stock M as much as it wants.
buickanddeere
10-10-2006 19:18:38
If they weigh the same? Depends all on the tire style, air pressure, rim width, hitch height/length, fore/aft balance and driver skill. As for the anount of "work" they can do? A 50HP tractor can perform 125% more owrk per hour than a 40HP tractor.
champspa
10-10-2006 14:27:09
M being 42hp, super m being 47hp, smta being 47hp and a 620 at 48hp it seems they should be a good match. with that creeper gear on a biting track it should outpull anything except a tractor with gears or hp to match
Ron 1456
10-10-2006 13:36:38
Every year at Fair time my son and a bunch of his friends take my Super MTA to a couple of pulls. This year they beat a 620 and a 730. Got beat by an M and MM ?. All they do is move weights around. Nothing special has been done to the engine. So tune up the M and go have some fun.
doc/osky
10-10-2006 19:01:24
 Re: Farmall M vs. 620 John deere in reply to Ron 1456, 10-10-2006 13:36:38
everyone get's lucky sometimes!!i bet my a with fenders, would beat all these tractors, wont to see then bring it to osage city!
mike's600
10-11-2006 03:53:27
 Re: Farmall M vs. 620 John deere in reply to doc/osky, 10-10-2006 19:01:24
A good 400 case will get them all.
