Changing the the weights in the governor
Stephen G
04-12-2002 16:35:20
Hi my name is Stephen ,
I have a John Deere model G . That has had the weights changed in the governor , and now has model B weights in it . People have told me that by having B weights in the governor that this should make my tractor more responsive. What do you guys think of this . thanks very much. Stephen G
lynn
04-13-2002 06:39:16
 Re: Changing the the weights in the governor in reply to Stephen G, 04-12-2002 16:35:20
Stephen..have filed down the weights a g..i think putting two springs on the govenor arm works for throttle response and rpms..lynn
Gman
04-12-2002 19:14:25
Stephen on my puller '51 "G" I installed B govenor weights,to cut down on govenor action at full throttle and I think is pretty effetive.If you are just loafing along it will pulsate a little,I don't think you would want to do this on a plow tractor. I have ran without any weights,but it is a little dangerous,when you are not hooked to sled,the rpms are hard to control boy she will turn on though. Experiment with them that's the best way to learn. Garland's two cents worth
JDG
04-13-2002 22:02:59
 Re: Re: Changing the the weights in the governor in reply to Gman, 04-12-2002 19:14:25
B weighs and G weights are the same weigh.
