Goodyear long bar/ short bar
puller4life
04-12-2002 18:49:47
Will Goodyear long bar-short bar tires be to my advantage or disadvantage with a stock tractor, we have to pull 1st gear we pull on a clay track?
Thanks for your help
dubie
04-16-2002 19:52:04
 Re: goodyear long bar/ short bar in reply to puller4life, 04-12-2002 18:49:47
Everyone in our club who has tried to use them doesn't keep them and I work for goodyear and use coop tires.
buckmaster 700
04-15-2002 21:52:17
why waste time and a wad of cash on a poor rubber compound that wont hold an edge get some firestone f151 s or b.f goodrich power grips
Jim M
04-13-2002 21:38:36
Goodyear designed them to stop wheel hop and long tread life not pulling on a clay track
Denny Frisk
04-16-2002 13:49:43
 Re: Re: goodyear long bar/ short bar in reply to Jim M, 04-13-2002 21:38:36
Actually GY made them to stop the shuddering of the Sound Guard Cab on the 4030/4230/4430/4630 model tractors when run on hard pavement. Run a Deere with Firestones, or GY Power Torques on the road and the cab will shake back & forth so bad your afraid the cab will collapse. The GY OEM Sales Manager at the time the "Dyna Torque" (first LB/SB) came out told Me that.
That's correct
04-16-2002 14:23:00
 Re: Re: Re: goodyear long bar/ short bar in reply to Denny Frisk, 04-16-2002 13:49:43
Those deeres aren't any good, they rehash an old idea and call it a new one and THEN they have to have the tire companies make a new tire because their tractors can't even drive down the road without breaking down.
deeres are junk
WVCRASH
04-13-2002 20:22:49
WE'VE BEEN PULLING STOCK TRACTORS A LONG TIME AND HAVE THE BEST LUCK WITH THE FIRESTONE 23% BAR TIRES
Dale13
04-13-2002 06:50:27
I've seen them work good on concrete pulls,mounted backwards.Wondered about tryng that on the rock hard clay we pull on in Locke NY?
Roy
04-12-2002 19:00:42
Didn't have much luck with a pair of them.
buckmaster 700
04-12-2002 19:58:33
 Re: Re: goodyear long bar/ short bar in reply to Roy, 04-12-2002 19:00:42
those tires barely make a good sand box for the kids
duckmonster 200
04-14-2002 09:19:05
 Re: Re: Re: goodyear long bar/ short bar in reply to buckmaster 700, 04-12-2002 19:58:33
Buck you could be right but the only saving feature of the long bar short bar is it can be made into a double cut with a tire machine
Firestone, not Goodyear...
04-16-2002 06:43:20
 Re: Re: Re: Re: goodyear long bar/ short bar in reply to duckmonster 200, 04-14-2002 09:19:05
you might be thinking of the Firestone version of the longbar / shortbar. The compound on the Goodyears is still too soft (without hardening) and I believe the tread angle is still wrong (unless you cut the doubles into the carcass meat).
